Folks: Since Dynamo is constantly evolving, it would be helpful if the currently installed version could be shown on the opening screen, right? (…trying to paste in an image, here …)
Thank you
If you know your Revit version, you know the Dynamo version
Well, I am currently running Revit 2022.1.30.34 (per “Help” menu), but the Dynamo Version (per “About …”) is 2.12.1.8411
Is there some sort of code in the Dynamo version that translates to the Revit version?
Mr. Marcel_R: Are you on the Development team, sir? It seems like showing the Version on the opening screen would be logical and simple - are you in a position to make that happen? If so, is it programmatically possible? If so, is it difficult, or would it be a simple and sensible addition to the interface? Thank you
Hello, on this side you will not have it in the menu bar
but accessible via python and nodes
for the information in this case saw the post after Mr. Pierson
cordially christian.stan
No,
I’ve seen some ideas of mine come to life though, sort of
