I often find older nodes need to be updated a little to work with newer versions of Dynamo.
For example, in Steamnodes’ Tool.AssemblyViews, I had to change the Output names from the original which had parenthesis and other things that didn’t work. There was no warning, just null outputs.
I guess not. I think that’s too much work, because the are so many custom Packages and Nodes. The most popular Packages get updated regularly anyways.
A Trouble Shoot sticky might be a good idea for when a Scripts isn’t working.
So some point(er)s what to try, look for or loo at. Or some a links to the best topic + solution for the most common questions.
Maybe even mention some add-ins.
I see many questions about exporting and importing to and from Excel. Some add-ins do a better job than a Script (or a sufficient for the OP)
i am very new to this. Can you show an example.
i thought would be simple to just create all my assembly views quickly. dont even need on a sheet for now.
I cant get it to work at all…I cant see where anyone else has either.
