Tools.AssemblyViews (SteamNodes): View Creation Failed
Hi, I’m getting an error from the node Tools Assembly Views of Steam Nodes:
It creates the views and sheet that I want, but it stops at placing the titleblock and assemblyviews with this error:
Line 80: View creation Failed
Wich is this line: sh=AssemblyViewUtils.CreateSheet(doc,a,tb)
knipsel
Python code:
#python nodes in dynamo 1.0
#proposed by Julien Benoit @jbenoit44
#http://aecuandme.wordpress.com/
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference(“RevitAPI”)
app = uiapp.Application
elt = []
for i in IN[0]:
	elt.append(UnwrapElement(i).Id)
tb=UnwrapElement(IN[13]).Id
catid=doc.GetElement(elt[0]).Category.Id
collection=List[ElementId](elt)
viewlist=[]
schedlist=[]
sheetlist=[]
# Start Transaction
for a in elt:
	views=[]
	if IN[1] == 1:
		v=AssemblyViewUtils.Create3DOrthographic(doc,a)
		views.append(v)
	if IN[2] == 1:
		ds2=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.HorizontalDetail)
		views.append(ds2)
	if IN[3] == 1:
		ds3=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationTop)
		views.append(ds3)
	if IN[4] == 1:
		ds4=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBottom)
		views.append(ds4)
	if IN[5] == 1:
		ds5=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationLeft)
		views.append(ds5)
	if IN[6] == 1:
		ds6=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationRight)
		views.append(ds6)
	if IN[7] == 1:
		ds7=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationFront)
		views.append(ds7)
	if IN[8] == 1:
		ds8=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.ElevationBack)
		views.append(ds8)
	if IN[9] == 1:
		ds9=AssemblyViewUtils.CreatePartList(doc,a)
		views.append(ds9)
	if IN[10] == 1:
		ds10=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionA)
		views.append(ds10)
	if IN[11] == 1:
		ds11=AssemblyViewUtils.CreateDetailSection(doc,a,AssemblyDetailViewOrientation.DetailSectionB)
		views.append(ds11)
	viewlist.append(views)
	if IN[12] == 1:
		for v in views:
			if Viewport.CanAddViewToSheet(doc,sh.Id,v.Id) == 1:
				Viewport.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
				ScheduleSheetInstance.Create(doc,sh.Id,v.Id,XYZ(0,0,0))
		sheetlist.append(sh)
doc.Regenerate()
# End Transaction
OUT=viewlist,sheetlist
What is going wrong? :confused:
I’m using Revit 2019, Dynamo 2.0.3 and Steam Nodes 1.2.4
Well…
I know what went wrong: The titleblock i fed into the node is a family instance but it needs a family type to work! :rofl:
