to create a physical model from an analytical model
Hello, I need help on how to create a physical model from an analytical model imported from robot structural to revit
You don’t need Dynamo for that, there is a built in command for this in Robot. I used this workflow successfully years ago. Here is a small tutorial video how it should work:
https://screencast.autodesk.com/Embed/Timeline/ef24104a-7c22-4c82-9822-7baf41302058
And here is a forum thread: https://forums.autodesk.com/t5/robot-structural-analysis-forum/exporting-from-robot-to-revit/td-p/7914631
If this automatic workflow doesn’t work, you can export to smxx file in robot, than you can read that file in Revit. Help on importing smxx files to Revit:
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-5DFF2393-B380-4DBE-8A01-EF35CE8C379C
