Is anyone aware of a node that will create a textnote where both vertical and horizontal alignment can be set at the same time…or a workaround to do so?
Thanks in advance!
Thanks in advance!
# Phython-Standard- und DesignScript-Bibliotheken laden
import sys
clr.AddReference("RevitAPI","RevitServices")
elements = UnwrapElement(IN[0])
if not hasattr(elements,"__iter__"):
elements = [elements]
for el in elements:
el.HorizontalAlignment = HorizontalTextAlignment.Left
el.VerticalAlignment = VerticalTextAlignment.Middle
OUT = elements
Do List.Flatten before you connect elements to it.
@Deniz_Maral, this is great, thank you very much! Any guidance on what needs done to the python script so I can enter these two lists into the python block to assign the appropriate alignment per text note, based on what I pulled from a .dwg import instance?
Let’s see if it works
Use List.Flatten after all nodes.
import sys
vertical = IN[1]
horizontal = IN[2]
for el,ver,hor in zip(elements,vertical,horizontal):
el.HorizontalAlignment = HorizontalTextAlignment[hor]
el.VerticalAlignment = VerticalTextAlignment[ver]
OUT = elements
Yes, I think this did what I was looking for. I really need to teach myself some python! Thank you so much for the help!
