TextNote - get rotation
Hello, I’ve found topics here about rotating TextNotes, but i’d like to do the opposite - try and get values of rotated TextNotes.
So far I’ve found that TextNote class in API doesnt have property “Rotation” (it does have Position), but TextNoteOptions class does.
Being a python newb i’m asking what i’m doing wrong here :slight_smile:
so far i’m getting AttributeError that there is no such attribute as Rotation…
# Import RevitAPI
clr.AddReference("RevitAPI")
#The inputs to this node will be stored as a list in the IN variable.
x = UnwrapElement(IN[0])
rot = []
for i in x:
	rot.append(i.Rotation)
#Assign your output to the OUT variable
OUT = rot
also i’ve tried this approach but that’s just freestyling at the moment
Okay, seems I’ve found it - its BaseDirection property of TextNote class.
Case closed!
