# Phython-Standard- und DesignScript-Bibliotheken laden
import sys
clr.AddReference("RevitAPI","RevitServices")
elements = UnwrapElement(IN[0])
vertical = IN[1]
horizontal = IN[2]
if not hasattr(elements,"__iter__"):
elements = [elements]
for el,ver,hor in zip(elements,vertical,horizontal):
el.HorizontalAlignment = hor
el.VerticalAlignment = ver
OUT = elements
It worked on my side when I wrote it but now I can’t test it because I am running on Mac. I can tell you that tomorrow.
Which version of Dynamo do you use?
OUT = elements
It will work. You should use those lists that you flattened.
import sys
vertical = UnwrapElement(IN[1])
horizontal = UnwrapElement(IN[2])
OUT = elements
There is something wrong with those Nodes then. They give you String as output. They have to be member of Horizontal or VerticalAlignment Class.
I will take a look tomorrow.
import sys
vertical = IN[1]
horizontal = IN[2]
el.HorizontalAlignment = eval(hor)
el.VerticalAlignment = eval(ver)
OUT = elements
