Can somebody explain why the potato comes wrong and how to fix it?
clr.AddReference('RevitAPI')
def u(e):
return UnwrapElement(e)
def toNormal(p):
return XYZ(p.X/304.8, p.Y/304.8, p.Z/304.8)
def type(name):
fil = FilteredElementCollector(doc).OfClass(TextNoteType).WhereElementIsElementType().ToElements()
o = []
for i in fil:
n = i.get_Parameter(BuiltInParameter.SYMBOL_NAME_PARAM).AsString()
if n == name:
o.append(i)
return o[0].Id
text = u(IN[0])
type = type(u(IN[1]))
vector = toNormal(u(IN[3]))
offset = IN[4]/304.8
pt1 = toNormal(u(IN[2]))
pt2 = XYZ(pt1.X+vector.X,pt1.Y+vector.Y,0)
pt3 = XYZ(pt2.X+offset,pt2.Y,0)
textNote = TextNote.Create(doc, doc.ActiveView.Id, pt3, text, type)
leader = textNote.AddLeader(TextNoteLeaderTypes.TNLT_STRAIGHT_R)
leader.End = pt1
leader.Elbow = pt2
OUT = pt1, pt2, pt3
Yeah, I need that elbow part, or whatever does it called, to be horizontal. I seems to be doing something wrong with adding offset to a vector.
Update:
It seems that script working correctly, it just the insertion point of the TextNote is at the top of it. So to get a horizontal elbow I need to add offset in the Y direction that equals to half of the height of the TextNote box. Now how can I get the size of it?
Maybe this helps?
def type(name):
o = []
for i in fil:
if n == name:
o.append(i)
return o[0].Id, o[0]
text = u(IN[0])
typeIn = type(u(IN[1]))[0]
typeHeight = type(u(IN[1]))[1].GetParameters('Text Size')[0].AsDouble()*304.8
Thanks that helps, but it gives me only the value of the text size… nontheless it is useful!
With a bit experimenting I’ve determine that for ever mm of text size Revit multiplies it with 1.85 and the scale value. The rest of the bounding box is extra space that equals to 3.345 times scale. So the bounding box is 1.85 * text height * scale + 3.345 * scale. I’m though not getting te desired displacement at Y axis.
def u(e):
def toNormal(p):
def type(name):
o = []
for i in fil:
if n == name:
o.append(i)
text = u(IN[0])
scale = doc.ActiveView.Scale
offsetX = IN[4]/304.8
tH = 1.85
eX = 3.345
offsetY = ((typeHeight*tH*scale)+(eX*scale))/2
offy = offsetY/304.8
#offy = 0
pt3 = XYZ(pt2.X+offsetX,pt2.Y+offy,0)
textNote = TextNote.Create(doc, doc.ActiveView.Id, pt3, text, typeIn)
leader.End = pt1
leader.Elbow = pt2
OUT = pt2.Y*304.8, pt3.Y*304.8
Hey, so I get something a bit odd…
Very basic maths, shift the point down by half the height of the font…
It is wonky, but if i shift my view scales around, it goes flat and stays there!
pt4 = XYZ(pt3.X-10, (pt3.Y-typeHeight/2), 0)
leader.End = pt1
leader.Elbow = pt4
Hmmm…!
It’s making it with the wrong placing and when you change the scale Revit changes the points positions in the way that the elbow levels out. It’s not what I’m after… The goal is to place like a thousand of notes on hundreds views at once.
Different workaround… I’ll let you re-write for lists.
def u(e):
def toNormal(p):
def type(name):
o = []
for i in fil:
if n == name:
o.append(i)
text = u(IN[0])
tH = 1.85
eX = 3.345
#offy = 0
leader.Elbow = XYZ(pt2.X, leader.Elbow.Y, pt2.Z )
leader.End = pt1
I’m not good with python, so for anyone if you need for the script to work in other view than active or with leader at different position or arc; feel free to modify the script to your needs. And maybe share. Because sharing is caring.
Ok, unfortunately I’ve run out of time, but here’s a version working with lists, I’ve kept everything simple so you can see the principle… you’ll need to feed a list of views, a list of lists of text & points… then run a For loop to go over the ‘zip’ in here… Have a go and post back
def u(e):
def toNormal(p):
def type(name):
o = []
for i in fil:
if n == name:
o.append(i)
return o[0].Id
text = u(IN[0])
pointsIn = u(IN[2])
#pt1 = [toNormal(point1) for point1 in pointsIn]
pt1 = []
for point1 in pointsIn:
pt1.append(toNormal(point1))
pt2 = []
for point1 in pt1:
pt2.append(XYZ(point1.X+vector.X,point1.Y+vector.Y,0))
pt3 = []
for point2 in pt2:
pt3.append(XYZ(point2.X+offsetX,point2.Y,0))
output = []
for point3, point2, point1, t in zip(pt3, pt2, pt1, text):
textNote = TextNote.Create(doc, doc.ActiveView.Id, point3, t, typeIn)
leader.Elbow = XYZ(point2.X, leader.Elbow.Y, point2.Z )
leader.End = point1
output.append(textNote)
OUT = output
Thanks for the list management!
If I understand correctly this part loops on it self, right? Because what is exactly the value of Y? I’m not getting it…
That is the default value of the leader, thanks to Jeremy Tammik
So no looping required, Woop!
Friends, how could I adapt this model to come up with this kind of presentation?
