Hello guys,
Is there any way ti set the text note vertical align?
We have a node to set the horizontal align but it’s missing the vertical node and the Set.ParameterByName doesn’t work.
Any help is welcome. Thanks guys!
Hello guys,
This is available from Revit version 2019.1:
Thanks Einar for your time but after the update still the error. I’m sorry but I’m not a programmer.
All what I want to do is to create a text note with Dynamo and set the vertical alignment to middle.
When the Dynamo creates a text note, the point location than you choose is different of the center point of the text after created, because of alignment
The center of text should be the same of the center of circle
Thanks again
