Can’t figure out wich node to use. Any suggestions??
I don’t think the string from array node is needed. The object you are reading is already a string?
The reason that you only get one item is that you haven’t changed the lacing in the SetParameter node from shortest to longest.
The cells causing you problems is in fact numbers so you have to convert them to strings. Personally I prefer the tostring converter in the springs package.
