Return value in column B corresponding to the value in column A in Excel
Hi all,
can somebody help me to identify which node to be used for getting the value in Column B corresponding to the value in column A in Excel.
This is the excel I have.
Thanks in advance.
Can you show us what you’ve tried so far in Dynamo? :slight_smile:
Thank you for the response.
Sure.
This is what I’ve done so far.
Here I want to replace the List.GetItemAtIndex node.
Hi there,
you could try to use this:
You probably want a dictionary node
As Andrew_Hannell said, you could use Dictionary nodes from LunchBox packages:
Cheers
Thank you… That helped… :slight_smile:
But i used the node List.AllIndicesOf node instead…
Will try that also… thank you so much…
Thank you Andrew.
:slight_smile:
