When I try to convert Number to String, I want to keep my data structure
Hi all.
I have a question. “A” is consist of Number items and I want to convert this to string.
but when I use Number.ToString Node, The data structure is changed like B
So I tried another way like C using Codeblock. but I think it is long… Is there a another simple way??
Have you tried the StringFromObject OOTB node.
Hi John!!! I really thank you!!
It looks like you’re using a really outdated version of spring nodes. A recent version might work better. Tho if you’re working with integers, the built in node should be just fine. The only reason why I added that node to springs in the first place, was because the built in node is too generous with the zeros on doubles:
