jshial
June 19, 2020, 2:01am
2
@vanman
I guess these OOTB nodes could not take care of RoomTag (AreaTag & SpaceTag also).
They’re calling IndependentTag.Create() then throw the exception:
On the other hand, Room/Area/Space tag has creation method NewRoom/Area/Space Tag, see the following, NewRoomTag() method requires less input and does not throw the exception you’re facing:
Existing packages could tackle this already, found in previous post, might want to give it a try.
Hello People
Im trying to place roomtags with the nodes:
Create Annotation Tag (ArchiLab)
Create Independent Tag (GeniusLoci)
Bad sadly those nodes returns an error: Line 196: There is no loaded tag type that can be used when tagging referenceToTag with tagmode.
The Roomtag Typ is loaded into my project. I tried other roomtags but i always end up with that error.
I dont know where i made a mistake. Im Using Revit 2018.3.
Could someone give me a helping hand? It would be much appreciated. […
