Hi ,there
Can somebody help me with this:
I need to tag all selected elements in all views where the element is visible.
I have tried this, but it gives an error :
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import BuiltInCategory
from Autodesk.Revit.DB import TagOrientation
from Autodesk.Revit.DB import TagMode
# Get current Revit document
# Get element to tag
selectedElements= UnwrapElement(IN[0])
views = IN[1]
t = Transaction(doc, 'Create Tag')
t.Start()
for v in views:
for e in selectedElements:
if True:
#if e.IsHidden(v):
p = e.Location.Point
xyz = XYZ(p.X,p.Y,p.Z)
// Error in this function,
tag = IndependentTag.Create(doc, ElementId(v.Id), Reference(e),False,TagMode.TM_ADDBY_MULTICATEGORY,TagOrientation.Horizontal,xyz)
#tag.ChangeTypeId(multicategory.Id)
tag.TagOrientation = TagOrientation.Horizontal
t.Commit()
It says I cannot use the id of a FloorPlanView as a parameter and instead needs an id of a View.
Does anyone know how can i converter FloorPlanView to view, or does anyone have another solution for this problem?
