Tag all remaining elements
Hey all, last post for today. Does anyone know of a node that does the same function as this? Ive been building a script but it needs to tag everything in one go
Everything in one view, or all views?
current view only. I have left over single elements. I could just tag them with the standard revit Tag all not tagged but thats an extra step
First step would be to identify them by pulling all elements of the desired category in the view. Revit 2022 and on should have “All Elements of Category in View” as an out of the box node; for previous versions you can use a similar node in Datashapes.
Next step would be to get all tags in the view in the same way, and quarry their host element (there are a few documented ways to do this on the forum - here’s one such method). It may be advisable to use a List.Unique node after this to clean up any duplicate items.
WIth these two lists you can pull the set difference with the List.SetDifference node. You may have to first convert to a compatible object type, in which case an Element.Id node would do the trick on each list.
From there any item which remains needs a tag. Note that if you converted to element id’s you’ll need to convert back to elements prior to tagging.
