I have attached my Dynamo graph for reference. This issue only seems to occur when running the graph in Revit 2021 and Revit 2022 (haven’t tried later versions.) This issue does not occur in Revit 2020.
When collecting faces from the “MultipleInputForm ++” node, “Surface.PerimeterCurves” returns the same geometry for every face collected - none of which correspond to the actual face geometry in my project. This is further illustrated by collecting the same faces from OOTB “Select Faces” node.
Edit: The issue is occurring when faces are being collected from Structural Columns. Faces collected from Walls seem to return the correct geometry.
My first thought is that perhaps this is due to some API change in Revit 2021? I’m not great at navigating the API documentation, so if this is true I haven’t been able to identify the change.
Does anyone have any insight into this?
Curtain Wall Formwork_Integrated Columns.dyn (171.7 KB)
