When using the Select Face UI node from Data Shapes Package the dynamo geometry is not matching the geometry when selecting the element (and face) from within Dynamo itself. I would have thought that the geometry of the face would be in the same location as the element geometry
The result being when I get a vector perpendicular to the surface it is not correct (particularly when the column is rotated within the revit file)
Surface and face by UI.dyn (10.4 KB)
