Surface in Dynamo to Model Space
The task I am aiming at is to loft Lines to create a Loft Surface.
In dynamo, my flow is like this:
Select ObjectsObject.GeometrySurface.ByLoft → (The last node for exporting to Civil3D space)
However, in all of the (something).ByGeometry nodes available right now, there seems not to be any Surface.ByGeometry nodes. I have tried with every .ByGeometry nodes currently available of them but no seems to work.
It would be great if you guys could tell me ways to do such a thing (if there are any nodes or packages supporting my case are available).
Thank you for your time!
Object.ByGeometry should do the trick, no?
Dynamo surfaces are currently not supported for geometry conversion to AutoCAD surfaces. You could try to use a mesh instead if your workflow allows it.
Yeah, to my surprise, Object.ByGeometry cannot do it :smiling_face_with_tear:
Thanks for your confirmation!
