Convert Surface (AutoCAD not Tinsurface) to Geometry Dynamo
I don’t convert Surface (AutoCAD not Tinsurface) to Geometry Dynamo. Please help me to do it.
HI
YOU NEED
Convert FROM AutoCAD LoftedSurface Properties >>>> to >>> Geometry Dynamo BY
https://help.autodesk.com/view/OARX/2022/ENU/?guid=OARX-ManagedRefGuide-__MEMBERTYPE_Properties_Autodesk_AutoCAD_DatabaseServices_LoftedSurface
thank you for your answer.
But you can show me your scrip dynamo?
Do you have Knowledge of using cad api
If yes
You need to write python code
For reading surface
https://help.autodesk.com/view/OARX/2022/ENU/?guid=OARX-ManagedRefGuide-Autodesk_AutoCAD_DatabaseServices_LoftedSurface_CrossSectionProfiles
Like this
if no
Can you look at this
can you use Command: _Thicken with 0.001
to get 3dsolid
Thanks, Sir.
Sorry, I don’t know Autocad API.
it’s cool. but I have many surfaces (~10000 Surfaces). this is Bad.
Now is a good time to learn. :slight_smile:
@khugt60
What is it The ultimate goal for cad surface
You can get what you want without the need to Converting to dynamo gemmetry
Can you attached example drawing
Please see the attached file in below. I want to get vector normal (Vector normal of surfaces at many points) for instance the ground anchor.
Road.dwg (2.6 MB)
Thank Sir!
Thanks, Sir!
I think it is good for me.
990
111
thanks Sir
This is great @hosneyalaa, thanks for sharing your knowledge.
