When you load the grid surface created with Civil3D into Dynamo, it becomes 「DynamoNodes.surface」.
I want to convert this surface to a geometry that can be moved with Dynamo, that is, 「DesignScript.Geometry.Surface」,
Which node should I use?
Object.Geometry might be a good start. Can you post an example graph if not?
Thank you, mzjensen !
I did well in that way.
