Hi everyone,
I’m quite new to dynamo and trying to display a surface created by a sweep in Civil3D. The script seems to work with the a solid and line. It’s also working in Dynamo itself. I can’t figure out why the node Object.ByGeometry is not working for the Geometry: surface. I’ve applied the following suggestions already, but that didn’t help. Dynamo for Civil 3D does not create geometry in the current document | Civil 3D | Autodesk Knowledge Network
Thanks in advance!
