Hi guys¡¡ Does anyone know how can i create a color surface gradient in revit using dynamo?? i don´t want to divide the surface in different surfaces…i would like to have a continuos surface but with a gradient color, anyone knows how can we do that?
Thank u so much
Yna_Db
January 3, 2017, 4:11pm
2
In Revit, I can only find this under Procedural maps, which are material properties. Not sure it could be set through Dynamo (but with Python maybe)…
yeah @Kulkul but with this node i only display color in dynamo or also in the revit view?
Kulkul
January 3, 2017, 5:41pm
5
You can use the PointAnalysisDisplay functions to display coloured points in Revit.
With enough points you could map an image to a surface
Has anyone attempted to apply a heat map on a wall? I’m working with boundary reinforcing and would like to show areas on the wall where MEP can not penetrate. I’m unsure if anyone has any experience doing this or if this might be achieved by using an image that can be refreshed. If this isn’t achievable through Dynamo maybe it’s possible through the API.
If you’ve done this or have a thought on how this might be done please let me know.
thank you.
Joseph_Peel:
could
I solved the problem using the node of face analysis display by view and face analysis data…it works perfectly
Thank u guys
Yna_Db
January 10, 2017, 8:50pm
8
Could you also send a screenshot?
Yeah i would like to see that too
