Hannes
1
Hi, i use Dynamp 1.2 and Revit 2016.
Is there a way to color geometry in Revit with Dynamo?
I tryed this with the node “Display.ByGeometryColor” but i only dye the geometry in Dynamo.
Is it possible to import new created geometry and color them in Revit? For example lines? and how?
In my example i dye existing geometry(walls) and try to dye created geometry (solid line):
Here is a link to similar discussion: Surface color gradient in revit
Steven
2
This should get you there.
@Hannes To change colors in Revit use Element.OverrideColorInView
Hannes
5
Thx Vikram…i don’t know why i haven’t found this node;)
wael11
6
Is there a node that does a similar coloring in Revit to Autodesk.DesignScript.Geometry.Line objects please?
truevis
7
That link no longer works in 2023. This still works: Revit.Elements.Element - OverrideColorInView
