Hi there,
we are renovating two apartment buildings, they get a prefabricated Wooden Jacket.
I guess life was easier in the '60’s if you see how straight the existing structure is.
Never mind , a surveyor will handle this next week, and he promised me he will deliver the copy by means of a spreadsheet.
I gave him the coordinates of the intersections of the gridlines by the eattext command in Autcad. He will produce me the corresponding references for each level.
So the question relates both to Revit as to Dynamo.
How do I make my model, in order to have the model “dance” according to the coordinates I get from my surveyor?
I guess You can make a script in Dynamo, to model the structural coloums & beams along a wirteframe, driven by the coordinates…If somebody has such solution, I would be happy to have a look.
But there is more to it than just the structure. I would like all the copy to get along, that’s one wall for each lateral facade, four windows in the rear facade, and two windows and two wals in the front facade.
-How do I build my model, in a “what you see is what you get” modus?
I guess aligning copy to revit gridlines is no longer usefull?
And How do I copy the copy? Now I added Structure, floors and walls to a separate Group, and pasted the copy to the 7 other floors, but I guess this is not compatible with my parametric exterior.
I cannot believe I would be the first with this assignment, so I am really looking forward to your feedback.
Kind regards,
Willem
