Orientation to the Element not to the view, how?
StructuralColums_V1.dyn (160.9 KB)
head_.rfa (360 KB)
Hello Dynos,
My Columhead is still a topic. My script is better than before, because i can filter by a Parameter “Stützenstil” there are 3 Values (“Vertikal”, “Geneigt - Winkel”, “Geneigt - Punkt”). These 3 Values occure as integer 0,1,2
The heads are oriented to the view, not to the Column!
How can i say that the placing is oriented by the colums.
I get a blue line (Starpoint.Endpoint) - How Can I orient my Element to It - I mean like a “relativ Coordinate System” related to each instance-element?
KR
Andreas
Since this has gone unanswered, here are my two cents: you may be able to get the transform from the columns family instances:
https://www.revitapidocs.com/2020/8c8aff2b-5ff9-e43a-3b5c-308cd0174f1f.htm
https://www.revitapidocs.com/2020/50aa275d-031e-ce19-9cfd-18a7a341ed19.htm
You might then use the transform of these columns to adjust their column heads, but since column heads are Generic Models, I do not know if/how transforms can be applied to them or if the properties of column tranforms can be effectively retrieved and applied to them.
clr.AddReference('RevitAPI')
def Column(x):
   return UnwrapElement(x)
y = Column(IN[0]).GetTransform()
z = Column(IN[0]).GetTotalTransform()
OUT = y,z
2020-09-07_13h49_27
What i call actually? points, Coordinates, rotations,… and finaly what can is see? Double, Strings…?
regarding the topic(Transform) i found this:
http://lubim.co/2019/05/10/room-boundaries-from-linked-documents/
You will probably have to tweak this and adapt it for the project, but you could do something like this:
StructuralColums_V1_Forum.dyn (58.6 KB)
I prefilterd the colums… … the script selects the slanted Colums.
GetStructrualColumns_V2.dyn (43.5 KB)
I have still problems with this index
Yeah, first and last index should be top and bottom of the columns.
But hey! I didn’t actually notice that the colums were round. My way of getting the rotation wont work, since im calculating it from a face.
Would need to get the rotation from the Project Base Point i guess?
Is the column slanted aswell?
Could you upload a small sample rvt file?
yes they are slanted…
… the vertical ones have a head integrated
Projekt5.rvt (2.0 MB) pinhead.rfa (360 KB)
First, I think we have to find the curve of the slanted column.
Then find its rotation with respect to the Y axis.
Slanted columns.dyn (56.2 KB)
GetSlantedColumnsSetStructuralColumnHead_V1.dyn (249.2 KB)
i think i did progress: because i got the Referenceplanes from my 2 FamilyInstances (head/Columns)
as you see i have to do something like “close the gab.” Can i do something like “map” values refplane(column) to refplaneColumnhead?
KR
Andreas
