Hello everyone,
surely a simple problem:
with String.Split, “semicolon and line feed” should be used as separators.
How must the separator be entered?
Best regards
Rolf
Hello everyone,
Best regards
Rolf
why does Dynamo show these results depending on the definition of the separators?
Best regards
Rolf
Why not use a String node instead? Just type the two values as you would in Revit (no hex needed).
Hi JacobSmall,
exactly the string node leads to a different result
than the string with code block
But why?
Best regards
Rolf
Hi Vikram,
String node with “enter as input” - so that’s the simple explanation!
Many thanks to the always attentive forum specialist!
Best regards
Rolf
