I am using the civil3d document extension and when i try to set a surface style i get a strange error all of a sudden. I was on holiday for a week and I could swear before my holiday it did not throw me this error:
the package version is 1.1.32 in case that matters
Just in case someone else comes across that strange error.
As I wouldn’t get it to work no matter what I did, I just created a python node to change the surface style instead:
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AutoCADNodes')
clr.AddReference('Civil3DNodes')
import Autodesk.AutoCAD.DynamoNodes as DA
#from Autodesk.DesignScript.Geometry import *
import Autodesk.Civil.DynamoNodes as DC
# import other references
from System.Collections.Generic import Dictionary
surfaceIN = IN[0]
surfaceStyleNameIN = IN[1]
cdoc = CivilApplication.ActiveDocument
editor = adoc.Editor
global adoc
global cdoc
with adoc.LockDocument():
with adoc.Database as db:
for _surfID in cdoc.GetSurfaceIds():
obj = t.GetObject(_surfID, OpenMode.ForWrite)
if obj.Name == surfaceIN.Name:
_surf = obj
if(cdoc.Styles.SurfaceStyles.Contains(surfaceStyleNameIN)):
surfStyleId = cdoc.Styles.SurfaceStyles[surfaceStyleNameIN]
_surf.StyleId = surfStyleId
editor.WriteMessage("\nSurface style set to: " + surfaceStyleNameIN + "\n")
t.Commit()
OUT = "Style Changed"
