Documentextensions.setstyle keeps throwing errors when I try to set the surface style as shown here:
Any idea why it does not work?
Can you check the outputs from the nodes upstream? They might return null as well.
Warning: DocumentExtensions.SetStyle operation failed.
Could not load type ‘Autodesk.Civil.DatabaseServices.PressureAppurtenanceSectionLabel’ from assembly ‘AeccPressurePipesMgd, Version=13.3.854.0, Culture=neutral, PublicKeyToken=null’.
The last node returned null after the first run because the surfaces didn’t had the style anymore that I Listed indices for on in the middle of the graph
I ended up modifying some python code to do the style change and seems to work. import sys
clr.AddReference(‘AcMgd’)
clr.AddReference(‘AcDbMgd’)
clr.AddReference(‘AeccDbMgd’)
clr.AddReference(‘AcCoreMgd’)
clr.AddReference(‘AecBaseMgd’)
clr.AddReference(‘AecPropDataMgd’)
clr.AddReference(‘AutoCADNodes’)
clr.AddReference(‘Civil3DNodes’)
import Autodesk.AutoCAD.DynamoNodes as DA
#from Autodesk.DesignScript.Geometry import *
import Autodesk.Civil.DynamoNodes as DC
from System.Collections.Generic import Dictionary
surfaceIN = IN[0]
surfaceIN2 = IN[2]
surfaceStyleNameIN = IN[1]
cdoc = CivilApplication.ActiveDocument
editor = adoc.Editor
global adoc
global cdoc
with adoc.LockDocument():
with adoc.Database as db:
for _surfID in cdoc.GetSurfaceIds():
obj = t.GetObject(_surfID, OpenMode.ForWrite)
if obj.Name == surfaceIN.Name:
_surf = obj
elif obj.Name == surfaceIN2.Name:
_surf2 = obj
if cdoc.Styles.SurfaceStyles.Contains(surfaceStyleNameIN):
surfStyleId = cdoc.Styles.SurfaceStyles[surfaceStyleNameIN]
_surf.StyleId = surfStyleId
_surf2.StyleId = surfStyleId
editor.WriteMessage("\nSurface style set to: " + surfaceStyleNameIN + "\n")
t.Commit()
OUT = “Style Changed”
