Issues creating an empty surface with dynamo
I’m trying to use Dynamo to import and clip a DEM. The process: create empty surface → add data clip boundary → add DEM. However, I cannot find a working way to create an empty surface. I’ve tried using a bit of code found here:
However, this code no longer seems to work. Every time the python node tries to grab the surface style styleId = cdoc.Styles.SurfaceStyles[styleName] an exception is thrown.
Could anyone point me in the right direction?
Hi
Can you share the python code you are working on?
and an example file
Since I’m just creating a surface from scratch any file will do. The error occurs when I attempt to subscript the style list e.g. “styleId = cdoc.Styles.SurfaceStyles[0]”. Remove the “[0]” and the error goes away. But I don’t know enough about the API to say why it’s behaving this way. As I understand it, I’ll need the style from this list for the TinSurface.Create() function.
Load the Python Standard and DesignScript Libraries
import sys
Add Assemblies for AutoCAD and Civil3D
clr.AddReference(‘AcMgd’)
clr.AddReference(‘AcCoreMgd’)
clr.AddReference(‘AcDbMgd’)
clr.AddReference(‘AecBaseMgd’)
clr.AddReference(‘AecPropDataMgd’)
clr.AddReference(‘AeccDbMgd’)
Import references from AutoCAD
Import references from Civil3D
The inputs to this node will be stored as a list in the IN variables.
surfaceName = IN[0]
styleName = IN[1]
editor = adoc.Editor
with adoc.LockDocument():
with adoc.Database as db:
        cdoc = CivilApplication.ActiveDocument
        # list of existing Surfaces
        #SurfaceIds = cdoc.GetSurfaceIds()
        #for surfaceId in SurfaceIds:
        #   oSurface = surfaceId.GetObject(OpenMode.ForRead)
        #  if oSurface.Name == surfaceName:
        #      myEnt = t.GetObject(surfaceId, OpenMode.ForWrite)
        #      myEnt.Erase(True)
        # Select a Surface style to us
        #styleId = styleId_list[0]
        #styleId = cdoc.Styles.SurfaceStyles[styleName]
        # Create an empty TIN Surface
        #surfaceId = TinSurface.Create(surfaceName, styleId)
        #newSurface.append(surfaceId)
        # get Object
        # surface = t.GetObject(surfaceId, OpenMode.ForRead)
        # Commit before end transaction
        t.Commit()
        pass
Assign your output to the OUT variable.
OUT = styleId
Hi
Try
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AutoCADNodes')
clr.AddReference('Civil3DNodes')
import Autodesk.AutoCAD.DynamoNodes as DA
import Autodesk.Civil.DynamoNodes as DC
def create_tin():
    global adoc
    global cdoc
                surfId = TinSurface.Create(db, "test")
                surf = t.GetObject(surfId, OpenMode.ForWrite)
                t.Commit()
                pass
    return surf
OUT = create_tin()
Hi all,
The last code sample does work, but i had the next code working in C3D 2021, in 2022 it’s not working anymore. Does anyone has a solution?
The lines
  • styleId = cdoc.Styles.SurfaceStyles[styleName]
  • surfaceId = TinSurface.Create(surfaceName, styleId)
    don’t work anymore
import sys
import math
Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference(‘AutoCADNodes’)
clr.AddReference(‘Civil3DNodes’)
#Import References from dynamo
from Autodesk.AutoCAD.DynamoNodes import SelectionByQuery
surfaceName = IN[0]
styleName = IN[1]
MaximumTriangleLength = IN[2]
MaximumAngleBetweenAdjacentTinLines = IN[3]
deleteSurface = IN[4]
def delSurface(surfaceName):
global adoc
myEnt.Erase(True)
t.Commit()
def selSurface(surfaceName):
global adoc
surface = “”
obj = t.GetObject(surfaceId, OpenMode.ForRead)
t.Commit()
surface = SelectionByQuery.GetObjectByObjectHandle(str(obj.Handle))
return surface
Boolean {deleteSurface}
True => delete surface and create new surface
False => Select surface
newSurface =
surfaceId=“”
styleId=“”
if deleteSurface == False:
newSurface = selSurface(surfaceName)
if deleteSurface == True:
print(“Start - Create surface”)
# Select a Surface style to use
print(styleId)
print(surfaceId)
# get Object
#newSurface.append (surface)
#surfId = TinSurface.Create(db, “test”)
#surf = t.GetObject(surfId, OpenMode.ForWrite)
       t.Commit()
       pass
       newSurface = SelectionByQuery.GetObjectByObjectHandle(str(surfaceId.Handle))
OUT = newSurface
Hi i think wrong in writing name style
Try using
styleId = cdoc.Styles.SurfaceStyles[1]
Hi @hosneyalaa ,
Unfortunately that doesn’t work, if you take a look at the link:
The sample code:
//change the style
ObjectId styleId;
if (civilDoc.Styles.SurfaceStyles.Contains(“Standard”))
styleId = civilDoc.Styles.SurfaceStyles[“Standard”];
else
// create a new style called ‘example style’:
.Add(“example style”);
// modify the style
SurfaceStyle surfaceStyle = styleId.GetObject(
OpenMode.ForWrite) as SurfaceStyle;
My code must work, as it did before.
Hi @JPS
what do you want to do You create a surface
and then change its style
Or
do you want Create a new surface style
and modify it
Because this is a different topic
I want to use an existing style.
First find the ID and then change the style.
Q10
FYI there are dedicated nodes for this in the Camber package starting in v4.0.0.
