Morning all,
does anyone know if there’s a settings that affect the STL Export facet ?
I get highly faceted curves when i export from a geometry created in Dynamo even though it’s perfectly round
Morning all,
Not sure if it would help, but you could try different unit options available on one of the nodes
STL for 3D printing not SAT but i will try the SAT into Rhino then back to STL
I would use the meshtoolkit export node
Sorry ![]()
Not sure if it is relevant, but, in an online STL viewer changing Display option from Flat Shading to Smooth Shading seems to smooth a faceted surface.
