About to try & learn Dynamo (& Revit!) - I can manually import a 100MB sat file into a section box & export a cropped section - into 10 off 10MB files. (SAT files)
This should be possible to automate using Dynamo (any tips)?
(is there any way to specify the size & co-ordinates of a section box - currently these slightly overlap - which is ok, but my searching around hasn’t uncovered how to set a box size accurately).
The sat file will then be opened in Inventor & saved as .ipt files - (thinking of using iLogic for this).
Currently the 10 section boxes are saved & reopened to import the next SAT files, then re saved & the updated SAT file exported.
