Continuing the discussion from Standardist:
Hello.
A new version of Standardist is available for download. Still about the creation of simple specifications and estimates books.
Way more easy to use and more stable. Feel free to use it, and upgrade it.
Changes from previous version :
IN REVIT FILE
- SDD library now independent from revit project / main model linked to the library
- no more parameter implementation settings in the model file. All specific parameters are now set in the Standardist Library file.
- grid and layout set for complex hierarchy keynote list
- simpler way to choose quantity type
- new schedules to check all data and calculate project price
- quantities calculated according to phases
- select root of keynotes transfer
IN DYNAMO FILE
- first CORE file implements calculated data and keynote names into item parameters
- second TRANSFER file brings all relevant data to excel file and vice versa
- stairs steps count now included in quantities
- basic MEP elements support ( ducts, conduits, pipes, cable trays and plumbing fixtures)
IN EXCEL FILE
- layout adaptation for longer keynote descriptions and wider hierarchy
- now work with “,” or “;” xlListSeparator setting
- style adaptation for 6-item keynote hierarchy
