Stair Rebar
i had this idea to make automatic the rebar for a stair, i tried made a code by copying another similar rebar but clockwork node that i needed is not supported for newer version of revit, is there a way to make without copyng it? i mean by curves by getting the face down face, the lenghier curve of the stair?
Can you let us know what node you want but can’t get, or share the work you have done so far?
What version of Revit are you working in?
Hard to provide a good answer without really knowing where the hole in your workflow is.
rebar.copybyvector but i think maybe using curves is the easier method since this node dont exist in newer version
