Springs.Element.SetLocation node problem (Finishing floor boundary)
Hi everyone,
I’m trying to modify the finishing floor boundary from room boundary by Springs node.
But it doesn’t follow the room boundary.
How can i modify node?
Thank you for your help.
Room boundaries don’t have a location that can be set. Instead their boundaries are controlled by the bounding elements around them.
Are you trying to modify the location of a room separation curve instead? In that case you’ll need to get the separation curve element. Clockwork has a Room.Boundaries node that will also fetch the bounding elements.
Thank you for your reply.
