Hi guys,
i was wondering if its possible with dynamo or in combination with python to edit the boundary. in case of intersection with wall, and then create a boundary around it.
thanks
Hi @wihibyusuf,
Did you mean sth like this?
It would be very helpful if you upload your Revit and Dynamo file. It is not really clear which object you are intending to change its boundary.
exactly like that yes. thank you, i can send it also but how did you do this! awesome!
I used Solid.Difference Node to do this and then sent the geometry back to Dynamo using DirectShape.ByGeometry node. This will result in a solid geometry to do whatever you want with, select its edges or simply send it to Dynamo. I’m sorry I’m not near a pc to show you the script, but you should consider the following:
Awesome. Thank you very mutch. I was looking for this quit al while. If it is possible please share the grapgh of it. Im very thankfull. In the meantime i will try to create the graph from ur previous text.
Greeting
Hi, sorry for the unclear answer. I just realized that there is already a custom node that does exactly what you want and much better than my idea. I did not notice your heading at the beginning that your object is a floor. My mistake!
All you need to do is to find the footprint (perimeter) of your wall as a list of curves. The host is the floor element.
here is the code:EditBoundaryFloor.dyn (21.8 KB)
You need two packages:
P.S. I do not think the way I got the footprint of the wall is very good but it works. Maybe there is a faster way. Try it yourself!
Good luck!
Thank u for ur effort, ill pick it up first thing tommorrow
@mohamed.m.matook thank you again. it works, i had to tweak al lil bit by adding ceveral walls en floors en setting the lacing to longest but you did the job. thank you
