I have a problem.
I want to hide all elements selected in all views so I can hide all of these imported wall tags at once and don’t have to do “hide by category” on all of these tags in all views.
But when I run the node CurrentSelection from the Springs package on the selected wall tags, it does not capture them (outputs empty list).
if I run the following dynamo nodes, where I get all wall tags in the project, I get nothing
But when I select one in Revit and do “hide by category”, it works, it hides all wall tags in view.
Why does this select these tags?
Can someone give me a solution?
Is there another node that can select this type of linked model, or is there any Python code that can make this happen?
thanks for reading
