Hi guys,
I walked into a problem. My goal is to make a selection of walls by myself. But with the select model elements node you have to cross in the section. I would like to select the walls by one click. Is this possible with Dynamo?
If this problem is solved, I think I’m also getting a new problem, because if I select walls with the select model elements node and place families it goes well. When I’m doing this again on other walls it deletes the selection. How can I fix that?
maybe some experts here can do…
