Spring Node - Select Faces - Not working for Beams & Columns?
hello everyone.
why this node is not working on Beams & Columns faces? it works well with walls.
I’m trying to get the faces and the points that I picked to select the faces.
how do I get the faces & points of beams and columns?
There’s an issue with the code in that node when selecting columns and beams. Unfortunately, I don’t know enough about the error to provide input on the fix. Data-Shapes has a node called “Select Face (s) (PickObject)” that works.
Hi ,
here is a fix for structural Columns and Beams
#Copyright(c) 2016, Dimitar Venkov
# Cyril POUPIN : fix for structural Columns and Beams
# @5devene, dimitar.ven@gmail.com
from  Autodesk.Revit.UI import *
clr.AddReference('RevitAPI')
def output1(x):
	if len(x) == 1: return x[0]
	else : return x
surfaces, gpoints = [], []
sel1 = uidoc.Selection
ot1 = Selection.ObjectType.Face
ref_list = sel1.PickObjects(ot1, "Select the faces and press Finish.")
for ref in ref_list:
	el1 = doc.GetElement(ref.ElementId)
	sf0 = el1.GetGeometryObjectFromReference(ref)
	if isinstance(el1, FamilyInstance):
		tf1 = el1.GetTotalTransform().ToCoordinateSystem()
		tf1 = Transform.Identity.ToCoordinateSystem()
	sf1 = sf0.Convert(ref, tf1)
	for i in sf1:
		ref = i.Tags.LookupTag("RevitFaceReference")
		# print(ref)
		if ref is None:
			i.Tags.AddTag("RevitFaceReference", ref)
	surfaces.append(output1(sf1) )
	gpoints.append(ref.GlobalPoint.ToPoint(True) )
OUT = output1(surfaces), output1(gpoints)
FYI @Dimitar_Venkov
@c.poupin @Dimitar_Venkov
Thank you for the code, but it’s not working with column surfaces and points. It works perfectly with beams and walls as I wanted.
Please check again
I have not been able to recreate this bug can you share your rvt file?
@c.poupin
binded.rvt (2.3 MB)
here now beams are also having problems!!
@vishalghuge2500 What’s your end goal in this scenario.??
Here is a workaround by recomputing References with StableReference
I’ve only done a few tests, so it’s worth trying out on several objects and several versions of Revit.
getSurfaceSelections2
# Cyril POUPIN : fix for structural Columns and Beams v2
import re
def output1(x):
	else : return x
	el1 = doc.GetElement(ref)
	el1Type = doc.GetElement(el1.GetTypeId())
	stableRef = ref.ConvertToStableRepresentation(doc)
	n_ref = None
	print(stableRef)
	# force to recompute refrerence
	if not ":0:INSTANCE:" in stableRef :
		print('pass')
		surface_repr = re.search(r'(:\d+:SURFACE$)', stableRef).group(1)
		new_stableRef = el1.UniqueId +  surface_repr
		print(new_stableRef)
		# dot not to reuse the ref local variable
		n_ref = Reference.ParseFromStableRepresentation(doc, new_stableRef)
		sf0 = el1.GetGeometryObjectFromReference(n_ref)
		sf1 = sf0.ToProtoType()
	elif isinstance(el1, FamilyInstance):
	for i in sf1:
		refo = i.Tags.LookupTag("RevitFaceReference")
		if refo is None and n_ref is not None:
			i.Tags.AddTag("RevitFaceReference", n_ref)
		elif refo is None and ref is not None:
			pass
@bharat.minocha
