Helpmi select face ? problem
revit dynamo does not select the selection module
Hi @hhtiras
Welcome to Dynamo Forum!
Looks like you have a command Revit Command active in Revit Background. Hit Escape and try selecting Face again.
Thank you very much for your interest, but there was no solution. The problem still continues.
I uninstalled the program, installed it again, but
Sorry, the problem continues. I cannot choose in the 3D viewing area.
Try Using Select Faces node from Springs Package.
Springs nodes Select Face Works fine. Thank you so much Kulkul.
You are a very helpful person, thank you very much
you told me very well thank you so much
