I am having a problem with one of data-shapes nodes for selecting model elements as an input for multipleform input ++ node. It works absolutery fine in revit 2019, but when I run the script in 2020 with the same (the newest) data shape package it doesnt work. Basically I need to select two different elements from view (one is for example a door, and the other one a detail component). I use node Selectmodelelements Data (2x), I create a single list and I plug it into the Multipleinputform ++. The problem is that in Revit 2020 when the dialog box for selecting elements appear, it seams it doesnt select anything. The multipleform is indices are empty.
I dont know if this might be a dynamo core problem or something. Any ideas?
Thank you
Lucie
