Select linked element faces
Hey people ! It’s good to be back to the forums !
I have an issue with linked elements i’m using a user interface with datashapes i have managed to select the linked element i want to use but i can’t seem to get its faces i’ve tried to get the geometry too but i keep getting the same error message ! Any help would be appreciated !
@deejaypein
workaround are bimorphnodes
# links
linked_docs = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RvtLinks).WhereElementIsNotElementType().ToElements()
# linked file
link_document = []
for link in linked_docs:
    link_doc = link.GetLinkDocument()
    link_document.append(link_doc)
link = link_document[0]
# walls
linked_walls = FilteredElementCollector(link).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
faces_of_walls = []
for elem in linked_walls: #for every element
    edges = [] #an empty list for the edges to process
    processed = [] #the list of processed edges which we want to keep
    geos = elem.get_Geometry(Options()) #the geometry
    for geo in geos: #for every geometry found
        if geo.__class__ == DB.Solid: #if the geomtry is a solid
            faces = geo.Faces #get the faces
            for f in faces:
                faces_of_walls.append(f)
OUT = faces_of_walls
i think that code can also be a starting point. It return all faces of a wall, from walls in a linked file.
The Bimorph nodes worke just fine ! Thanks for your help !
Is there a way to select the face i need from a linked element without a collector it would be so helpful
you can use pickobject methode
selection = uidoc.Selection #type: Selection
# links
# linked file
link_document = []
# get linked wall
#Prompt user to Select a Linked Element
ref_selected_elements = selection.PickObjects(ObjectType.LinkedElement,"Select Linked Element") #type: Reference
#Get Linked Element ID from Resulting Reference
ref_lnk_id = [ref_selected_element.LinkedElementId for ref_selected_element in ref_selected_elements]
#Get RevitLinkInstance from Selection using ElementID
selected_elements = [doc.GetElement(ref) for ref in ref_selected_elements]
faces_of_walls = []
for elem in selected_elements: #for every element
            for f in faces:
you have to refactor it, i choose multi-selection.
Another solution is to directly select the faces of the linked model.
select_linked_faces
code Python (compatible with IronPython3 or CPython3, except CPython3 in Revit 2024)
import sys
import System
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI.Selection import *
class FaceSelection:
    def __new__(cls, *args, **kwargs):
        cls.args = args
        # name of namespace : "CustomNameSpace" + "_" + shortUUID (8 characters)
        # IMPORTANT NOTE Each time you modify this class, you must change the namesapce name.
        cls.__namespace__ = "FaceSelection_tEfYX0DHE"
        try:
            # 1. Try to import the module and class. If it already exists, you've probably already created it once, so you can use it.
            module_type = __import__(cls.__namespace__)
            return module_type._InnerClassInterface(*cls.args)
        except ImportError as ex:
            class _InnerClassInterface(ISelectionFilter) :
                __namespace__ = cls.__namespace__
                def __init__(self):
                    super().__init__()
                def AllowElement(self, e):
                    return True
                def AllowReference(self, ref, point):
                    if ref.ElementReferenceType == ElementReferenceType.REFERENCE_TYPE_SURFACE:
                        return True
                        return False
            return _InnerClassInterface(*cls.args)
lst_DSface = []
TaskDialog.Show("Selection", "Pick Several Faces")
refs = uidoc.Selection.PickObjects(ObjectType.PointOnElement, FaceSelection(), "Pick Several Faces")
for ref in refs:
    # get Face Geometry
    sel_elem = doc.GetElement(ref)
    if isinstance(sel_elem, RevitLinkInstance):
        tf1 = sel_elem.GetTotalTransform()
        linkDoc = sel_elem.GetLinkDocument()
        elem = linkDoc.GetElement(ref.LinkedElementId)
        if isinstance(elem, FamilyInstance):
            tf2 = elem.GetTotalTransform()
            tf1 = tf1.Multiply(tf2)
        face_ref2 = ref.CreateReferenceInLink()
        face = elem.GetGeometryObjectFromReference(face_ref2)
        lst_DSface.append(face.ToProtoType())
        elem = sel_elem
        face = elem.GetGeometryObjectFromReference(ref)
OUT = lst_DSface
Thanks for the reply ! This is for sure helpful but i need to prompt the user to select the face directly on the revit linked model not the element and than collect the faces
This is exactly what i was looking for thank your for the contribution
Hello again good sir ! i’m having a bit of a problew with the surface i get from the selected face .
It seems i can’t use it to host a family type. i’m getting this error
Hi @deejaypein PS the only node i know there get the linked surface/reference is that one @Draxl_Andreas show from bimorph…another way could probably be with genius loci…
Here is an update version with 2 lists at the output
  • list Surface
  • list Reference
import sys
import System
        cls.args = args
        try:
                def __init__(self):
                    super().__init__()
                    return True
                        return True
                        return False
lst_DSface = []
lst_ref_face = []
rvt_link_instance = []
for ref in refs:
    # get Face Geometry
        lst_DSface.append(face.ToProtoType()[0])
        lst_ref_face.append(ref)
        #print(ref.ConvertToStableRepresentation(doc))
OUT = lst_DSface, lst_ref_face
then you can use the ‘FamilyInstance.ByReference’ node as mentioned by @sovitek
awesome as always :wink: thanks Cyril :wink:
and a way with pick points, could probably work as well
Revit_ynaazG18kf
