I’m still relatively new to Dynamo and Revit, so I’m probably missing something basic…
I’ve used Sastrugi Package to allow the user to pick their starting point, if it’s more than one it just takes the first, but then the Spot Elevation just returns null… am I misunderstanding what it needs as inputs?
Hi there,
I can think of two reasons why you’d get a null value.
Firstly make sure that your active view is in fact a floor plan view (you can temporarily use the “views” node, to check).
The other reason I can think of, is that there is no element beneath the point that you selected.
Hi @TurtleWolfe
Setting the Sketchplane before Point selection should ensure that users are selecting points relative to the view content ![]()
