Spool sheets with this node its working but not in proper way. so please someone help me about this
Hello @Gowtham and welcome to the forum :wink: keep in mind steamnodes havent been upgraded for years…which version are you in ? in 23-24 you will need open the node and edit some input and set it to ironpython 2.7 and be sure you have that dynamoironpackage 2.7 version 2.5 installed as well…hope it could help…
PS…I havent tried in 25 or cpython3
Hello @sovitek thank you for solution, can you drop a script here. as a beginner it will be useful for me
just open the node and rename as here…try it and if doesnt work, just let us know and we can go deeper
edit; should work with cpython3 as well
and if you only wanna create these views with you input bool true, you will need click at the input and turn off "use default input and give a bool false in all other input…all input is set to true "default in the node or set the input in the nodes input to false
Hello @sovitek thank you for solution, now the script runs perfectly. is there any possible to add view template in views. because views are coming like this
Screenshot 2024-10-03 094919
yeah try set the view template as here
@sovitek where i can download viewtemplates node because i dont have that
that one is from rhythm and can be installed from packagemanager
Hi @sovitek is there any possible to align the views in sheet ?
Hi @Gowtham thats actuelly a new topic :slight_smile: but you could try play around with set.location or move by vector…here is a fast exemple with set.location…i use rhythm and genius loci
Revit_alIjjLuGW4
Hi @sovitek thanks for script :wink:
yeah you are welcome, try play around with it :wink:
Hi @sovitek is there any possible ways get mark values automatically assign to the spool assemblies. because i generate spool sheets by using dynamo but i didnt get the mark values in pipes & fittings. i need your solution for this issue
Yeah it should be possible…but let us close this one here…and create a new topic…cheers
ok :+1:
