I’m trying to split or divide my wall vertically and later one horizontally, so my walls have the correct size for fabrication, but i have run it to some issues, that i hope you can help me with
i have at this point, collected my wall and gotten the line, that a want to divide, but the method i use to divide the line do not seem to work, and i hope that one of you awesome people out there can help me with that
@rgs It is not possible yet to divide walls. It is a restriction. Read this on RFO Split Wall using Revit API - Autodesk Community. However you can get the existing walls curve and divide it and then create a new walls at last remove the existing once. Good Luck!
I know we cannot split the wall directly based on what I have read here. So I am following your advice to create new walls based on the curves obtained by dividing the curves of the existing wall. What I want to achieve is pretty simple - divide a wall into two where it is being intersected by another wall. Illustrated in the images below:
Above images depict a simple example but I want to do it for a larger project with multiple walls and wall types.
I tried using two methods:
Using Element.Location to get the Wall Curves and Endpoints and then splitting the curve using the nodes below:
