I’ve checked out a bunch of posts about splitting beams or columns, and I’ve read them all, but I’m still stuck with the same problem.
I’m trying to split beams at their intersections with other beams using the Split ByPoints node from Genius Loci in Dynamo. The issue is that when I run the script, it doesn’t always split the beams at the intersections, as you can see in the image.
I’ve tried so many different approaches, but I still can’t figure out what’s going wrong and why it’s not cutting in the right spot.
I’ve also attached the Dynamo file in case anyone can spot the problem.
BB_CortarVigas_V6.dyn (33.5 KB)
