Split Multiple Lines From Multiple Points (Beams From Columns)
Hi All,
I have a basic knowledge of dynamo and usually i found my many previous solutions on this forum. But i stuck at this one and not able to make it work.
I want to split multiple beams from multiple columns. this is a small portion of a large projects. i am getting unusual result from curve.splitbypoints. please any help would be appreciated. i have attached my files below for your reference.
Revit:2020
Dynamo:2.3
Split beams From columns.dyn (131.7 KB)
Test File.rvt (3.5 MB)
Below is the few topics that i found but i can’t make it work correctly.
[Split Beam at Intersections with Columns][How to use "Curve.SplitByPoints?]
https://forum.dynamobim.com/t/split-beam-at-model-line/4100
Thanks in Advance :sweat_smile:
Hi @rkitact,
Welcome to the Dynamo community.
You were almost there!
I’ve tweaked your logic and it worked for me.
See if it works for you as well.
Split beams From columns-Amol.dyn (56.6 KB)
OMG! It’s Worked…
THANK YOU VERY MUCH @AmolShah
