Hi all,
I am trying to filter the elements that their list contain at least one true value but when I tried to use the filter node it doesn’t seem to work for me. So, would anyone be able to help me please. Thank you.
Hi all,
If you’re looking for anything with at least one True value then you need to find those lists first. Try using the AnyTrue node.
Hi Scalelah,
Hope this is what you require.
Alternatively, you can also use the AnyTrue node from Clockwork to do the same.
@AmolShah @Nick_Boyts
Hi both, both of your solutions worked perfectly fine for me. Thank you very much for your help
