Sublist filtering
Hello everyone.
I tried to filter a sublist which contains true and false. I want to include all points, but only the lists that contain false.
Can you help?
Use FilterByBoolMask node. “In” output will be true, while “Out” output will be false
Hi @jacob.d.nielsen ,
If you want to check if all items, per sublist, are equal, you could use multiple methods (both with the same output):
  • List.AnyFalse, set to @@L2.
  • List.AllTrue, set to @@L2 with a NOT gate behind it.
Then using a List.FilterByBoolMask node you can filter on just the lists that completely match or not.
It works, thank you very much.
