Filter Multiple Elements from a List
Hello everybody,
I have a problem in list.contains node. I have two lists. the first one has 9 elements and the second one has 2 items. I want to have a boolean list of nine elements where those two items list will be true and the remaining will be false. So, lis.contains node gives me only one true and the remaining of the list is false. I played already with lacing and still doesn’t work. Can anybody help me find out how to make it work with list.contains or any other node that can achieve the same purpose.
thanks,
Not sure why that isn’t working, I do most my list manipulation in Python (sorry in advance my coding is pretty terrible I’m self taught and still pretty new to coding)
There’s my example I used, where IN[0] would be your full list that contains all the items possible, and IN[1] would be the list of items you want to check are present in the full list.
Heres the code:
dataEnteringNode = IN
output = [False] * len(IN[0])
for i in range(len(IN[0])):
for j in range(len(IN[1])):
if IN[0][i] == IN[1][j]:
output[i] = True
OUT = output
thanks for your quick reply.
I tried it and still didn’t work though.
Open your Python node and screen shot your the code you typed, that’s a syntax error not a handling error
it works. just that closing parenthesis by protogeometry. I deleted it and retyped again and it worked.
thanks a lot.
true
