Hello Forum
I was hoping someone might be able to help with an issue I have with creating a solid sweep on a curved path. I have created a path (curve) with 2 arcs and 2 lines and joined into a list to form a polycurve. I have used the CS to locate the profile to sweep. The solid sweep works fine with 3 sides of the path but when you add the fourth curve it fails - “Warning: Solid.BySweep operation failed.
Unable to update solid by sweep : SWEEP_INVALID_RESULT – Sweeping could not create a valid body.”
I tested the Curve.IsClosed node and this stated true that the path is closed.
Solid Sweep profile.dyn (18.8 KB)
Thank you for any help.
Tim
Two issues here.
- The profile that you’re sweeping starts on the corner so it won’t make a good corner - you need to place it somewhere in the middle of a curve, far enough from the corner that it won’t be intersected by the profile on the return trip.
- The Solid.BySweep needs to be able to cap the ends in order to create a solid of itself. Your profile and your path are both closed there is no ‘open’ end on the swept geometry, and as such it has nothing to cap.
I solved problem 1 by getting the point at parameter 0.5 instead of 0, but other parameters should work as well.
Problem 2 is solved by using a Curve.SweepAsSurface node instead of a Solid.BySweep node. The result of the Curve.SweepAsSurface can be converted to a solid with a Solid.ByJoinedSurfaces node.
Hi JacobSmall
Thank you very much for your help. I will give this a try and I can see now why it is not working.
Thank you again.
Tim
try this
Edited Sweep.dyn (9.2 KB)
